Window Woes
Airbag
first my hoofy girlfirend breaks a window in the house after a row, then the firkin car won't start. Turns out after much fuse checking that the negative Battery clamp was loose. And I only checked them week. So then all the electric windows wwork, but the drivers side doesn't go up on it's own, I have to hold the switch. Turn off ignition with it down, turn it on, window now goes fully up and down without holding the switch.
But the drivers side passenger window won't go up up and down on auto, but is ok if you hold the switch. What do I do, other than get my girlfirend to bust that one too.. :(
All the rest are ok. Looks like loosing the Battery has confused summat. Either the girlfirend goes, or the car. I'd rather keep the car.
There is a description in the Instruction manual how to "Normalize" the windows. You raise the window by pulling the switch and hold it for another 2 seconds after the window is fully closed.
// ulro
I'm glad to see you've got your priorities right Airbag. Get yourself a...:beer:
It's cooking dinner by way of an apology. Bust window fixed, car now ok. :D
I'm a happy airbag again.
B)
