Nice!
RossP
Shouldn't be a problem, as they are for pre-facelift. But obviously you wouldn't be using the reverse and fog that are included in the cluster
EDIT: Here's A rough translation...
The light shadows on the lamps is can see are of the flashbulb of my digital Camera, on that its also that the back lamp shining !!!!
Here you get will encounter see a stern lamp Set such floodlights you on none.
The stern lamp are with a plastic cover lasiert..
The Lasierung is Waschanlagen-, polish festival and scraper festival.  Strength heat and icy cold make the Lasur also nothing.  The Kunststofflasierung was applied in 2.5 layers breath thin and are therefore
To recognize the test numbers according to lamps type just as like before.
+ discreet blackly lasiert +
+ all lamps with E check character +
+ Professional Lasiereung and Sonderanfertigungen +
The lamps are brand-new Lasiert.
The lamps can be registered also, lies however in the estimating of the inspector
If you can majke out that then good luck, but they seem to be fine and comply with e-mark
indeed! sort of thing i would have got
Instead of using tights?? :P
I like them... Me feels a purchase coming on!!! :thumbsup:
E-mail them...I know my smoked ones i got were for LHD as fog and reverse lights are wrong way round. But they must do them somewhere for RHD!
