Granvia Brake Pads
:thumbsup: had our Granvia for just two weeks and adore her,for peace of mind when towing our caravan would like to renew the brake pads but don;t know where to get them,can anyone help?Plus how do I go about getting oil and fuel filters etc?
all brakes, suspension, bodypanel, etc... the same as UK 96-on hi-ace power van
engine the same as 96-00 uk land cruiser colorado (prado) 3.0 TD, anyway, the hi-ace 2.5TD service bits will do
:thumbsup: many thanks this information proved invaluable thanks again.
I have a 96 Imported Granvia and we recently had a slight knocking sound from the passenger-side front wheel area (only at slow speeds). Our local garage has had a look today and indicated that the brake-pads need changing (fair enough at about £55+vat) and also the suspension has gone (will need to source from Japan - and will take about two weeks )
Should I tell him to use the same parts as for a UK Hi-Ace powervan which should be available from the shelf?
:yes:
yes as buesun predicted you cant go wrong with the uk Hi Ace powervan brake pads at £12.99 a pair from our local auto parts shop and presumably the suspension should be just as easily sorted.
what suspension bits u need, got a set of replacement shock space, i replacement mine with KYB shock.
all bits the same, make sure bits from 96-on model Hi-ace powervan
