:P does anybody know if the alloy wheel size pcd 4 x 108 et 15would fit my toyota paseo.
I'm so clueless about these things.
Cheers
Adrian
that pcd is incorrect for the paseo mate, it will not even bolt onto the hub!
Rich.
Rich.
Hi Rich,
do you know what size will fit.
I honestly havent a clue and don't know how to find out.
Cheers
Adrian :help:
youre pcd is basically the distance between the centre of the opposite bolt holes im mm
the paseo has a pcd of 100.
as for the offset, im sure one of the seo owners will be along soon to advise you on that.
hope it helps ;)
Rich.
+40 - 42 i think it was
hope it helps ;)
Rich.
:thumbsup:
Rich,
you're a star matey.
Much appreciated.
Adrian :D
:thumbsup: Much appreciated
Adrian
