Abs?
car#4
Hello everybody!!
Im new to the Celica world, had a 1991 GTR for just over a week.
Gotta question,
My dashboard has an ABS light in the corner that doesnt come on EVER, and it also has a fuse for ABS under the bonnet.
How do I tell if I have ABS??
TA!!
the ABS sits on the drivers side of the engine bay at the front next to the relay box, if you can post a pic of your engine bay and it'll be pointed out, con't post one of mine cos i don't have it
Thanks for the quick reply!!!
Will post pics as soon as I get my hands on a camera.
Got another question....
Under the 3S-GE stamp on the cam belt cover, there's a yellow sticker that says UL on it. Is this an engine revision?
Cheers!
try braking if it locks up , the abs is either broken or its not fitted.the light is meant to come on on initial start up for a check then go out.
Thanks.
I'll try it, and i'll try checking the fuse too.
What does the ABS unit look like?
drivers side , left hand wing , biggish metal box with lots of metal pipes comming out of it.
