Questions
SupraKeen
:help:
I still need cams, does anyone know where I could obtain these? Bit short of funds at the moment so the best deal possible is needed. If I put used cams in would I then have to shim them up?
Do I need to do any rewiring from the ECU to the Dash as I got a Turbo Dash with the Turbo gauge in?
Could you give me more info on removing EGR, do I take cover off and just blank holes with plate?
Karma Supra - You mentioned that you had the engine loom, downpipe and various pipes that I would need, How much do you want for these?
I already have the ECU.
Was it RAF Coltishall that you were going to pick up from?
Thanks!
