I.c>e.for Sale
starletsy
I.C.E. for sale
Calibre CA 80.4 Four channel amplifier, connectable as a 2-, 3of 4-channel amplifier. Max. 4x 80W (2x 160W mono), RMS 4x 40W (2x 80W mono) at 14.4V. 2-Ohm stable stereo.
Planet Audio 12” sub, dual 4 ohm vice coils this is a serious sub made in the USA that will need between 250 and 500W RMS fed to it. It comes with a custom built sealed Birch Ply box that was built to the correct specifications for the sub. The box is 45cm wide x 42 cm long at it’s highest point it is 32cm high sloping down to 22 cm high.
Jensen Nitro amplifier, 2 x 125WRMS or 1 x 250WRMS 2-Ohm stable
Brand new ANL fuse holder with a 300 amp fuse this is high-end kit for systems needing plenty of power.
2 x Fuse holders been used but in good condition these will take anything from 20-80 amp fuses
1 x distribution splitter block splits down the main power feed into two separate feeds also individual fuses again takes anything from 20-80amp fuses.
2 x 4m RCA wires
1 x 5m RCA wire
1 x 0.5m 4AWG power wire red
1 x 4m 4AWG power wire red
1 x 0.5m 4AWG earth wire black
4 x 1m 8AWG power/earth wire red
1x 1.5m 8AWG power/earth wire red
1x 1m 8AWG power/earth wire red
Also assored speaker wire and remote wire and a sub box connector was having a clear out as I’m moving house.
Would like to sell as one kit for £150 this is a bargain the wiring alone would probably be near £100 new. But might split if I get enough sensible offers for all the kit.
Located in south Lincolnshire.
Simon
