Lost Locking Wheel Nut Key!
djdave
:ffs: I bought a celica GT a couple of weeks ago, really nice, perfect in every way EXCEPT it has toyota locking wheel nuts on it & I don't have the key, the last owner lost it. Can anyone help? It looks like it has 3 prongs if that helps?)
Only had that problem once, and it was fixed without damaging the wheelnuts at all (did damage the tool we used though)
We had a "magic socket" in the tool box, it was quite a big socket full of hexagon shaped spring loaded pins, the idea being that it works on any size nut even slightly rounded of nuts.
Luckily the magic socket just fitted in the hole pushed around the nut and we were able do undo it change the wheel and put the nut back on.
Unluckily the pins all got bent inside it!!
Might be a solution to remove them :thumbsup:
