I think I have a leak in the petrol tank of my 94 RAV4. First of all is it one tank that goes across the vehicle or is it a double tank? I suspect the leak may be coming from the top of the tank where the outlet is which would mean removing it to work on it. Any advice would be welcome. Thanks.
Thought I would reactivate my original posting since lots of folks have looked at it but no one seems to have the answer. Even if you havn't taken the tank out but have a manual or any info. this would be very welcome. Since my original posting I think the leak is not actually from the tank but from where the flexible fuel line is connected to the solid one coming out of the the top of the tank. To confirm this will require me to drop the tank at least partially if not actually remove it. By the way I amn pretty certain it is a single tank which is made very shallow and goes across the breadth of the car. This will be for ground clearance. Please pass on any ideas. Obviously others are interested.
Jocky
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
