3sgte Pcv Question
Does the Mr2 3sgte have a pcv one way valve from rocker cover to pre turbo intake, in addition does it have a vacuum to throttle body also to positively pressurise crankcase with air to mix with blow by gases to make them less volatile, and this would be under vacuum also?
the same engine as a 91 gt4, we call it the rev 2 3SGTE in GT4 speak...
....cheers.
