Alloy Wheels
boyracer666
cos ive got 195/45/r16 kosei's, dont wna keep the yaris standard
wots the 'PCD 100, ET 35-42'
PCD - 100 is the yaris's PCD.
e.g. distance between 2 of the bolt holes (100mm)
if your alloys have a pcd greater/less than 100mm they won't fit
ET - 35-42 is minimum and maximum offset (am sure u can go to 45 though)
check for ET on the inside of your wheel/tyre and u should see a number next to it
