Fuel System Cleaners
IceHz
I haven't ever heard any horror stories or anything wrong with fuel injector cleaners, though for the most part they just contain a concentrated form of the same additives that are already in most petrol.
If I were use a fuel injector cleaner, I'd probably go with the Chevron product with Techroline, just because I've read some positive things about that particular additive from the API.
I wouldn't bother with any of that stuff until higher mileage though. Say 60k+ miles.
I have not used any injector cleaner on my Yaris :)
I bought some Wynn's Engine Flush.
I think it goes into the Oil, It says to change the oil filter after.
I suppose it's because of all the sludge that gets moved about.
I thought I would put it in before my 60K Service in June.
Do you think I should tell Toyota that I've used an engine flush and for them not to do one? But please change the oil flitter :-)
do NOT drive with the engine flush in the oil!
you put it into the oil prior to oil change and let the car run for about 10-15min... then change the oil and oil-filter...
Ummm Cheers for that.
Thanks guys for the input... will post if i see any improvement after using it.
and vladrulli thank for the warning about engine flush :o ...
Cheers
:thumbsup:
