Stalling Problems
I seem to have read that many people are having difficulty with their toyotas stalling at lights and have tried replacing just about everything under the sun. I have taken my car to the dealer 3 times now and they cannot duplicate the problem. The car had been rear ended and originally I would loose power when making right turns. Gas tank level didn't matter. Then the car starting dying while stopped at lights, in traffic but would always start back up. Diagnostics have been run & no codes come up. The latest issues was loosing power on the freeway. When trying to accelerate there was nothing. Car was still running. Coasted 4 lanes and after coasting on shoulder of freeway car all of a sudden "had gas" and I made it home. Is there one thing that seems common with all of these stalling incidents. I don't want to replace everything in the car. I am concerned about safety at this point. Any help anyone has would be greatly appreciated... Thanks....
  • 2 months later...
Could you add an update? What exactly has been done to try to fix the problem?
  • 5 weeks later...
i am having the same problem i have changed gas filters ,cleaned throtle body and had diagnostics run .no trouble codes showed up have you found out what the problem is yet i don't want to spend a fortune
