Alignment!
Ryan1985
Okay, the inside of both of my front tyres are really badly worn, since I have had my HKS wagon suspension fitted I have not had my wheels aligned! Would this sort this out?
Also, can I get them aligned on my standard steel wheels and then just put my alloys on and it'll be fine?
Cheers :thumbsup:
P.S. Mods please do not move this topic into the wheels and tyres bit, I need as much coverage as possible! :)
you should have had your alignment checked after about 2 weeks of changing the suspension.
the inside wear will practically defintely be due to the alignment being out.
why do you need to change wheels?
but anyway - no dont change wheels.
get your alignment setup on the equipment you drive every day. Even better - get a full geometery checkup.
Thanks Matthew, just didn't want to drive about on my alloys with its new tyres (due to the worn old one's from the alignemtn being out :( ) allowing them to wear down on the inside.
Tried looking for a place that does the geometry thing but I can't find anyone near who does and is it not really pricey?
I'll get them aligned with my alloys on and keep a check on the wear.
Could it be the camber?
Thanks again. :thumbsup:
A geometric check will soon tell you... get it organised asap
Camber and toe.
^^^^^^^^^ = geometric check... get it done m8 trust me.
Btw, i think its tracking you want done?
Nah its alignment mate unless they are the same things? :wacko:
