Afternoon all,
Since i've had my car (2 Months) its driven nicely however on sunday i noticed something strange. :eek: I had just driven from near henley back to chorleywood (approx 30 miles) and i noticed that having come off the Motorway and driving on 'town' roads that my power was sort of surging :unsure: . For example if I put my foot down in second gear it would hold at around 2000rpm for a second or two and then shoot upto 4000rpm. Do you think the engine is becoming coked up? Is this a sign of other things or could it be down to a dodgy tank of petrol??? (I always run it on Shell optimax)
Also what does twin-cam mean? ( other than having two cams - whats the benefit?)
Sorry for droning on - i must like the sound of my own fingers hitting a keyboard!! :P
mine does that at times too.
iv been told though, that it could be due to fuel, and something else.. but cant remember.... :/
anyone help, as id be keen to know too.
probably your dizzy cap - im just about to go outside and change mine :thumbsup:
Twin Cam just means you have two cams ! (8 valves on each)
the advantage of more valves (and so more cams) is that more air / fuel can get into the cylinders per stroke.
i would change your plugs / dizzy and poss leads if your are having problems like you explain.
Thanks - i'll give it a go. Where would you guys suggest getting these items from?
