Help, Info Needed
immy1
hi,
need some help,
put key in ignition and it just wouldn't turn, the steering lock is on and just doesn't want to open(the standard steering lock-not a seperate one). i cant get the key to unlock the steering wheel. key goes in fine and comes out fine. tried some wd40, didn't help. been told i will have to change the lock barrel,(dont realy what to!)
any ideas?
how hard is it to change the ingnition barel, and how much would i be able to get one for? where from.
any info would be great.
thanks guys
Hi Immy1,
Remove the upper and lower plastic covers around the switchgear.
Put the key in the ignition and rock the steering wheel left to right while trying to turn the key to the ACC position.
Under the barrel housing you will see a small round sprung loaded peg.
Push the peg in and pull the barrel out of the housing.
Key has to be in the ACC position to do this
Hope this helps you
:thumbsup:
thanks,
i'll try that. only problem is the key doesn't move, tried all day yesterday tryin to get it to the acc position. i'll try anyway, and let you know how it goers. thanks
