Good old sticking calipers again :yes:
Driving to work this morning to find the front left had started to slightly stick again (I would only say about 20% on)...had this a couple of times before and as you know its a common problem... :ffs:
Going down to a mates later today to strip the caliper again and give it a clean...always does the job but its a pain in the backside...
:ph34r:
yip.. like you said a well known Toyota issue.
All done and sorted...one of the pistons had stopped working...the rubber seal had gone missing somewhere???
Anyway took it all apart...cleaned everything down and greased back up again...is working a treat now...
Were getting good at this now as it only took us an hour from wheel of to wheel back on....
haha
