hey guys seeing as i don't know much bout the paseo or engines in general :blink: i was wondering if there are any performance mods that would really gain me some speed/acceleration, ahahaha. thanx in advance
to be perfectaly honest mate if your gona want to do some serious mods to the engine of the seo the best option is to swap it as that is the best way to gain power.
Alternativly with the stock seo engine things like induction kit, plugs, leads (poss v low boost turbo on the gen1) are your only real option.
swap engine out is the only feasible " cheapish " modification to your disposal...
otherwise, if you're willing to dump loads of money, build up the block of the current engine (cylinder liners, pistons, con rods....) and then turbo it, you can use the 4e-fte turbo (some kits available), or there are other kits too
