Hi, i have a Celica Convertible 2.0 Auto, 1995 non ABS. I've been told i need a new O/S CV joint including gaitor and for the N/S just the gaitor kit.
I've tried looking but as yet have had no luck. I have however had one quote from a garage of £181 for the CV joint fitted and £39 for the n/s gaitor fitted. This sounded a bit steep?? Not sure. But looking at prices of joints, they appear to be around £40?
Can anyone recommend any suppliers, i would be extremely grateful.
get one for a uk motor ,i was quoted £53 for a abs cv joint so non abs will be cheaper i;m sure it will be the same part , gaitors are around £10 , it will most likely be the same parts as whats on the st202 celica with a 3sge engine.
i can supply you with a new cv joint and gaiter for £60.
