Lo ppl,
Ok i own a 95 mr2 GT-T-Bar,I went to replace the rear pads and came across all sorts of bother,first of all the caliper is help on with 1 bolt at bottom and a slider at top,my previous cars have a bolt top and bottom which u remove and caliper comes off very easy. With this it is ver awkward to get off but i eventually got it by also removing the main bolts that hold the caliper support bracket on. Ok next prob the piston wont go back in to replace with new pads,does the piston screw in the way or should it just be pressed in? I now have a g-clamp that i may try again tommorrow but if its rainin its goin straight to a garage lol,another question,is there anywhere online i can download a manula for this or will i need to goto toyota and buy a manual? anyway thanks in advance for any information given :thumbsup:
This *may* be of some help
http://mr2manual.teq.org/
It's not very coimpelte, but could point you in the right direction.
