Awesome I.c.e. Package
morpheus1870
Ok pps
No sound system is complete without one simple element... Bass!!!
Let’s cut to the chase. Today’s most mind-blowing (and respected) sound systems demand the earth-shaking rumble of Audiobahn bass. You know the reputation. SPL and sound quality competitors across the world trust Audiobahn's line of hefty and reliable subwoofers to blow the competition into another dimension. Boasting superior power handling, low frequency response and undeniable good looks, Audiobahn subwoofers have taken the car audio world by storm, offering bass solutions for virtually every sonic environment. From beginners to competitors, anyone with an ear for music can join the Audiobahn bass revolution.
AUDIOBAHN Special Edition Series SUB WOOFER
For a limited time, Audiobahn offered the Daniel Jones Special Edition series of woofers exclusively crafted by the renowned product designer. These woofers incorporated the D.Jones signature and Special Grill.
AW1251SE
12” NATURAL SOUND WOOFER
45 oz. Strontium Magnet
Power Handling: 400 watts R.M.S.
Frequency Response: 24Hz - 1kHz
Efficiency: 92.1 dB
PHAT Foam Surround
Non- Pressed, Non-Transfer Paper Cone
KM3’ Coated for Virtually No Cone Distortion
2” 4-Layer ASV Voice Coil
Dual 4 Ohm
2 Ohm or 8 Ohm Operation
Mounting Dimensions: Depth; 5 1/4”
Hole; 10 7/8” Diameter; 12 1/2”
Multi-Connect Lug Lock Terminals
Front with special edition grill
Without grill
Back
Looking for a subwoofer that delivers great bass accuracy with unmatched style? The Natural Sound series features a non-pressed, non-transfer paper cone and PHAT foam surround for quick, distortion-free bass response. The awesome chrome plated stamped steel basket features Audiobahn’s trademark flame design and Lug Lock terminals. Designed for maximum sound quality without breaking the bank, the Natural Sound AW1251 features a vented and extended pole piece, a 2" ASV former with four-layer high-temp 4 ohm voice coil.
BRAND NEW
ORIGINAL PACKAGING incl KEY
MANUALS & GUARANTEE
12" Subbox Sealed and Carpeted
12" 1.0cu.ft 3/4" MDF box
Carpeted in black
Pre-built
Typical box size: 360mm(H) x 440mm (W) x 320mm (D)
BRAND NEW
VOODOO V350.2 Amplifier
700w max output power
Four class "AB" high-current dual discrete drive stages
Class "AB" technology MOSFET PWM Power Supply
Bridgeable & TRI-Mode Operation
Continuously variable 12db/octave high pass & 12db/octave low pass crossover
Subwoofer variable crossover for deep bass control
Enhanced variable bass boost +12db @ 50Hz
Enhanced variable treble boost +12db @ 10Hz
Gold plated RCA & Power, Speaker Terminal
Soft start & muting
Overload, thermal, short circuit protection
Power & protection indicator
Remote level control
Double side epoxy through hole PCB board (FR-4)
AMP
TERMINALS
BRAND NEW
ORIGINAL PACKAGING
MANUALS & GUARANTEE
ROCKFORD FOSGATE POWER
8 AWG AMPLIFIER POWER KIT RP1721-C
Your system is only as good as the weakest link. Not all installation components are created equal. Rockford Fosgate amplifier power kit gives you the edge with Wire Technology that pays off in imporved performance and clearer, tighter sound.
5.2M (17 ft) 8 AWG POWER WIRE
1M (3 ft) GROUND WIRE
AGU FUSE HOLDER W/40A FUSE
REMOTE TURN-ON-LEAD
RING TERMINALS & HARDWARE
BRAND NEW
ORIGINAL PACKAGING
PRICE: £240 INCL P&P
