Howto: Fit Clear Indicators
I didnt have to alter any wiring when i changed mine and you havnt mentioned drilling a hole for the side light bulb :thumbsup:
Russ
Russ
Didnt have to drill any holes?
Russ
Ive seen some mate where the sidelight is combined with the indicator..
Where as most are seperate bulbs.. :thumbsup:
Also i would suggest you use some cloth over the screwdriver before prising the unit out as you will risk scratching the paintwork.
Most MR2's have a seperate bulb forthe sidelights as i stated above hence shy you have to dril out another hole to place it in.
there are a couple of very good guides about on the net already.. you should have a look at them.. :yes:
Nice work though.. good to see people wanting to share their info with others.. :thumbsup:
