Should I Be Worried?
lewis23285
Hi all,
Well, I collected my new Yaris on Friday and I love it too much :D !!!!!
I have one slight worry, nearly every time I turn the engine on I get a blue warning light which looks like a little thermometer on two wavey lines. I've checked in the car manual, and apparently this means LOW ENGINE COOLANT TEMPERATURE ENGINE LIGHT. Normally I wouldn't be worried, but sometimes this light stays on for up to nearly 5 minutes :eek: is this normal???
Thanks guys,
Lewis
PS if I wanted to change the gearbox oil, is this difficult and how is it done. thanks guys!
It's just a polite reminder to drive gently until the motor has warmed up.
When it goes off...
LET RIP AND FLOOOOR IT...
if you're on a track that is,
but try not to go over 3k rpm when the blue lights on...
It used to worry me too - but it really is perfectly normal..
Mine came on today for a few mins even tho it was 22 degrees..soon went off after 2 mins or so :yes:
When it goes off...
lol I love that little disclaimer Matt! :lol::lol:
Yes.. this is perferctly normal.. when the engines heats up a little, it goes out
You'll find it takes longer in the cold damp weather - but in the summer is normally off again within a couple of mins ...
Like everyone has said - just dont rag the behind off it unitl it goes off
It’s all been said already, I think it’s a nice little touch by Toyota.
This time of year it warms up around 0.8 of a mile. In the winter it can be another mile on top of that before it goes out, all depends on the ambient temperature.
I keep it at low revs as mentioned until then.
Yeah, it disppears in less than a minute here on most days. Sometimes less. :thumbsup:
0.8 miles.......... i find it to be between 0.86 and 0.973.
on average.
sionic, you mean it acctally even lights up :P
PMSL.....
You took the words right outta my mouth on the guesstimate there earpl....
Lewis - have you driven any other cars before? You may have noticed this temperature guage in different forms in other cars hopefully!!!! :D
Like Moffmo says, try and keep below 3k rpm. I do it on mine. Then for the new few miles, I don't go above 4k rpm...
Totally normal, your car is fine! :)
When its goes out you can give it a ragging! :thumbsup:
