Mot Failure
whiteGL
just abit of advice needed.
my corolla failed on excessive Co2, its a '90 GL 1.3
whats the best way to cure this?
thanks,
mark
Was it only 'emissions' that it failed on?
If so i'm supprised they didn't 'let it go' if it was only that ...they usually do with an older car... ...allegedly ;)
Firstly was the car 'warmed up'? before the probe was stuck up it's exhaust?
Secondly take the air filter element out (or performance filter off if fitted) as a 'quick trick' just for the test.
If nether of the above works then turn the mixture screw down a little on your carbuettor just for the 'test' (car will probably be 'chugging a bit afterwards) then after you've got your 'Pass/ticket' turn it back up when you get back home to how it was running before.
All the above I have done myself with some older cars... ...allegedly :rolleyes: , but not that old because if car is pre 1975 then emission part is not performed/required.
As far as i'm concerned the 'Emission part' of the M.O.T Test is complete 'b :censor: locks' as it's not a safety item. Brakes, suspension, tyres etc are and need to be checked as could be dangerous. However a car with high emissions ain't as harmful as lets say what a power station chucks out.
Sorry for the last little rant. I'm a strong believer of sensible vehicle safety regulations but not for burocratic rubbish they are now adding to the test.
Some carbs have a C02 adjustment screw.
KidKoala Posted Today, 08:24 AM
Being stuck in a time warp :lol: I was not aware of that, with me when it comes to Carbs, its simple things like SU, WEBBER and AMAL.
As said before I am only reciting from my own experiances from my years of motoring.
alrite mate an ekotec valve will help im sure,
they do make a bit of noise but are all good mine cost me £50.00
and it will help on petrol do a search on these on the net i think i may work.
you just have to cut one pipe and job done jhave fun and let us know how you get on.
