Experiance Wanted
johnsuzi
i,m sure that one of you will know about these that are on sale at e-bay and are they any good(worth getting or not or any drawbacks) here,s the desc they give thank,s john
ANY MODEL
With Electronic Speedo Sensor
If you have a Japanese import vehicle and the speedo still reads in KMH then the car will be limited to 112 MPH.
This little micro chip will convert electronic speedo signals from KMH to MPH which means you can keep your original clocks in the car & there will be no more guessing what speed your doing with a 100% accurate mph reading. There is also a special wire on the unit which goes to the E.C.U which will remove the 112MPH Restriction, you can also put this wire to your cruise control to derestrict that.
It takes about 20 mins to fit and anybody with little experience with cars can do it because it comes with full easy to understand fitting instructions
take a look at -- www.eliteinternational.co.uk , i'm sure these guys will answer all ur questions
if your car was sva'd the speedo should read mph and should therefore be de limited already as mine was.
thanks for that will try out your link cheers john
