Towbar Electrics
chkbrk
2004 Corolla T3 D-4D. I need a 12v supply that is live when the engine is running but cuts when the starter motor is engaged. I need it for the relay for the 'S' socket on the towbar.
Try a Smartcom relay from www.towsure.com
Easy to fit and negate the need to hunt down an ignition controlled supply as they only allow 12V through to the caravan/trailer fridge/battery when the alternator is giving out a specific voltage (above 13.5 volts I think)
I used one on my last towing installation on a Land Rover Discovery in a previous life as a caravanner, and it was very reliable and worked very well.
Was this response any good to you??
