Hand Book
charandeep3@aol.com
I recently purchased Toyota Avensis 52 REG 1.8GS VVT-I. Could anyone tell me where can I get the manual handbook from, Is it possible to download from net? Because I am confused about some of the controls like OD and ECt Power. I am a new member, Please help me someone.
I take it you have an automatic. :bookworm:
The ECT button (which stands for "Electronically Controlled Transmission")
changes the shift points for the automatic transmission. When engaged,
the transmission shifts later, allowing the engine to get to a higher
power level and accelerate faster. Fuel mileage is usually reduced in
this mode. Use it when you need to get up to speed faster; for example,
to merge into fast moving traffic. The normal position for this switch
is OFF.
OD, or OverDrive, is a 4th gear on the transmission that will engage
when you are going above about 35 mph that lets the engine operate
at a lower speed (RPMs) when all it has to do is maintain a high speed
when you are going over flat, even roads. This improves fuel
economy. Technically, any transmission gear with a ratio of less
than 1:1 is considered "OverDrive". OD can normally be left ON
except when going up a gradual hill; the overdrive tends to not
give the engine enough power to maintain a steady speed. This may
cause the transmission to annoyingly "hunt" between 3rd and 4th gear. Keep the O/D on all the time, I don't even know why they give you the option to turn it off - Econ with no loss of performance - look at it as an extra cruising gear.
ECT - Only have it on when your 'sporting' it around.
Economy Patterns
O/D on/ECT Off - Most economic :thumbsup:
O/D Off/ECT On - Least economic :eek:
Hope this helps.
Nick............
The last 2 avensis I got I purchased from a main Toyota Dealer. Both times there was no manual with the car, first time round the dealer got one for me. The last time the dealer kept forgetting about it so I sent an email to Toyota Ireland and I had one in the post the following week. :thumbsup:
is OFF.
Economy Patterns
Hope this helps.
Nick............
Thanks very much Nick, You really have helped me a great deal. Thanks to everyone who answered to my topic.
