Help Fellows!
Vlada
Did sombody read my post "Shamless Avensis production problems" (yesterday).I 'm pretty serious with this.
Did somebody had the same problems or any of those with corrosion and turbine failure?
BR
:help::help::help:
I have not suffered engine block corrosion (yet). But the rubber seals of the doors and boot corroded badly within a year or two of purchase. They were replaced under warranty, but recently I noticed that the seal of the windscreen is badly cracked and corroded. My warranty ended this year - I will keep you posted as to whether Toyota takes responsibility for this (it is a2002 car)
In general have been very dissatisfied with car - lots of production bugs. Steering replaced twice under warranty, terrible moldy smell from AC, etc., etc. Would never buy again.
Good luck.
BR
:help:  :help:  :help:
I have a 2003 old shape D4D and have had no problems at all apart from a slight brake judder which turned out to be incorrect wheel balance.
Sorry you havent had lots of feedback but I've noticed on this forum a lot of people are less interested in the technical problems people have and more likely to reply if you talk about fat wheels, body modifications or in car entertainment.
Good luck with your cars in the future :thumbsup:
