How To Remove Stubborn Stains...
winstonitis
Hi All,
I need to remove the 'Twin Cam' sticker on one of the doors as it is well perished, tried thinners but it won't shift it.
Anyone recommend a good sticker shifter?
Cheers...
Lighter Fluid (seriously), it'll dissolve the glue pretty well. The hard part's picking off a wee bit of the sticker in order to drip the fluid in.
use a hair dryer to heat up the glue to make the removing of the sticker easier, then as above for removing the glue ;)
I used lighter fluid for cleaning adhesive off plastic once - works excellant - never used it on paintworked metal before though. :thumbsup:
Hair dryer (carefully), then lighter fluid or any high alcohol based fluid works brilliantly..... ;)
I got my emblems off using a combination of a hair drier, isopropyl alcohol and dental floss.
if you want your neighbours to think you are truly insane - let them watch you "blow dry" your car :D
Do you think i could use lighter fluid to get tint spray off my paintwork sprayed my back lights on a windy day :lol: tint spray on both back wings.
