Apart from air filter and exhaust what else could you do on a Mrk2 Turbo to increase BHP. Is there other turbos you can fit or upgrade? what's the first 5 basics mods to give you that extra bhp?
inducktion kit
Zorst which has to include a Decat for full effect
Manual boost controler and up the boost.. (within limits of safty depending on your car's year of manufacture)
Do that first and then you can move onto other mods.. :yes:
Sort of in order :
Exhaust (inc decat) is a must.
Air Filter.
Manual Boost controller (you need a decent boost gauge as well for this) 1 bar is a good guide.
Prob need new cooler plugs for more boost
Then your talkin more cash, but :
uprated intercooler
uprated turbo (stg 1 - 3)
mapable ecu or air/fuel controller
Forged Pistons
Steel conrods
Bigger Cams
2.2 stroker kit...........
The list can go on....... But id go from the top of this list
***EDIT - You will need a FCD to up the boost ! *** :huh:
Willa an HKS FCD type K fit an mr2 tubby???
if so I have one for sale!
bpu pretty much includes intake/exhaust, uprated ic, some sort of boost controller, fuel cut/boost cut defencer to up boost, and maybe 1step colder plugs to help agains detonation. i think thats pretty much basic upgrades until fuel and reliability becomes an issue. then if u want more, start upgrading fuel (bigger injector and better flowing fuel pump), uprgraded turbo(td06, gt series turbos, etc etc of sourse u need a new dp to fit it), external wastegate, ems, water injection...like boundsw said, it goes on and on and on.
