Hi i have a 1991 (h) g limited import, when i pull off in the morning and put my foot down, when i change from 1st to 2nd it seens to take a while for the rev counter & car to pick up speed!!!
after a few times it is ok
Sounds like you need a new dizzy cap and spark plugs.
jerry!!
Is this when the car is cold?
And then it behaves itself when it's up to running temp?
It is worse when cold but sometimes does it when warm too!! but not half as much <_<
