Tein Damper Basic
zebidi
hello. had the damper basic kit from tein fitted on. always hits the arches when throwing it round a corner. not at insane speeds but acceptable ones lol. has anyone else had this problem? what should i do? the dampers arent adjustable :angry:
harder springs? is it available? seems the only way i can get it to stop rubbing is to raise the ride height. i have 17" super leggeras on it with 205/40/17 toyo t1s
any help much appreciated
mine touchs too :D on hard bumps,but the springs on the teins are already harder than the TTE springs i had on before.
The only way to stop it rubbing is to raise the ride height,
its a choice you make really :huh:
Well mate, il let u into a little secret. Get the arches done. Ive done the back ones myself with a little help from a grinder :wacko: & they are dropped down to the bottom.
As for the front, i have adjusted them 11 full turns from the bottom & it doesnt rub. The cars going in to get the front arches rolled & widened in 2 weeks.
Hope this helps :D
i was gonna do this but does it weaken the strength of the car in any way and if you were to have a crash is it balently obvoius youv been hacking them?
Cheers
Matt
Na mate, the inner & outer skin of the back arches are pressed 2gether but i havent taken them too far. Ive just taken them down enough so the 17s will fit in nicely :D
Dont be worried about losing strength, it'll be fine :thumbsup:
dude where do u live? lol would like you to do mine. what would rolling the arches cost me?
I have heard you can get stretch marks from doing this is this true?
im just really stuck at the mo. really want to thrash it round B roads but dont want to raise the height. how much would i have to raise it by? 10mm? it will look too high then :( dumb dampers!!! not adjustable :angry:
Mine started rubbing on the rear when i changed tyre brands, the side wall on the new tyre was more upright than the old ones so i had to fit some bumpstops which sorted it out.
Is that the rubber that fits in the springs?
No, the one that goes over the piston on the shock absorber.
these things you mean? or something else? where to get them from?
http://www.funkystyling.co.uk/parts/item_d...php?prodID=4044
I soppose they would work but i used a rubber bush. I got mine from Demon Tweeks.
