Alloy Size
GRD008
hi, i'm new to this forum and just bought a new corolla.
i'd like to know what's the biggest size of alloys it can take without any modification to the body, the most sensible size, and also wheter the spedometer is affected from the change in wheel size.
Hiya i rekon you can get away with 18 inch rims on but the arch will probably shred the tyre. I would go for a set of 17inch as they are the most sensible and if you lower the car slightly it will make it look better. By the way a friend of mine just got a set of alloys called RV4's and they look really nice. You should check them out!!!!
