Remote Keyless
micky3
Anyone please tell me how to program a new remote to a 1998 avensis before i set the car on fire :ffs:
1)open drivers door, Insert key into ignition then remove it
2)close all doors...then open any door twice within 40seconds
3)within 40 seconds:
4)Insert key into ignition, then remove it
5)close all doors...then open any door twice
close all doors
6)switch ignition ON and OFF once to program a new remote code whilst retaining the origional codes, or twice to program a new remote code whilst erasing the original codes.
7)Remove Key
8)System should now Lock and Unlock Vehicle, once or twice depending on which mode has been selected
9)Within 25 Seconds:
10)Press and hold key lock button
11)Press unlock button 5 times
12)Release Lock button
13)Press and release lock or unlock button once.
System should now lock or unlock vehicle
..Programming Information Taken From"Auto Data CD", i b1nda am not responsible for any miss-hap that may happen during programming.
Wow!
do you have to rub your tummy and pat your head while doing all these actions???
it sounds like black magic ritual :-D
Makes my method of re-sequencing a keyfob simple by comparison!
:wacko:
close all doors
7)Remove Key
Could be doing something wrong but not working. thanx anyway mate :thumbsup:
My remote unlock button did not work, my manual says:
sit in driver seat
1. Open driver side door without the key in the ignition
2. Put key in ignition en turn from off to on, wait 10 sec
3. push lock or unlock button twice, you should hear the sound of the (ub)lock mechanism.
I did this procedure for both the lock and unlock button. Now both buttons function.
Hope this helps.
sit in driver seat
Hope this helps.
i need to set up a new key fob that is for setting one up that you have already had working :thumbsup:
close all doors
7)Remove Key
Is this a wind up?? I need to programme another keyfob for my 1998 avensis. Anyone know where I can get a key cut that will also work on the alarm?
Cheers
Adam
