First of all, whats the recomended lubes & coolant etc for a '96 surf?
Secondly, How do I remove a triple din Kenwood system (I want to try plugging my PS2 into it)?
Thirdly, how the hell do you work the GPS? It's all in japenese :blink:
Thanx for any help,
Sean
I have a service sheet that you can have, just let me know your email address, coolant should be about 10ltrs total, give it a good flush and then mix about 35-50% antifreeze
Remove 2 screws in the centre console box, and another 2 either side of the gearstick, take off the rear heater knobs and move the box back about 2 inches, you should be able to lift the gearstick sorround off, then pull the dash/radio panel away from the radio at the bottom and unclip the two switches from that panel, also you might have to remove the ashtray, once thats all out of the way you will see the 4 bolts that hold the radio in.
Do you mean the one in the dash or the roof mounted one that some people have.
Thanx for any help,
Sean
Tis the one on the roof, in front of the mirror
Thats the one, so reading that, do I need to reset my clock to Japan time????
Or is it just useless over here (it's just that I thought GPS meant GLOBAL positioning system???)
I have not heard of anybody getting it to work, so it's a bit like the Tv and Sat/Nav that I have in my surf "USELESS"
Just dug everything out! Thanks for the instructions, pretty spot on!
I've plugged the PS2 in to the screen but the screen seems to run at a different speed to ours? I've asked Kenwood sales if this signal can be converted (I assume from 50Hz to 60Hz?) but I doubt they will reply.
