Tidy Those Arches Up Boy!
Moffmo
Urg, look at that screw/bolt, it sticks out doesnt it
Ruins your bueatiful arch, and catchs on your tyres every now and again :rolleyes:
Lets take it off with a 10mm spanner or raquet (sp)
Go on TAKE IT OFF... dont be scared
And swap it with this!
A stanley 4mm (5 will probs fit as well) LONG rivet
Put your rivetor thing on
AND SQUEEZE BABY, SQEEZE AGAIN, SQUEEEZZEEE, SQUEEEZEEEE IT,
*Snap*
Well done
Looks alot better and should stop cutting into the tyre as much...
Ony took 5 mins as well, You will have to jack the back wheels, but you dont need to take the wheel off :thumbsup:
Cheers
Matt
  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
  • Moffmo
    15
  • earpl
    13
  • Blaze
    6
  • seveer unaek
    4
And when you have a bump and need to take whatever that bolt was holding off... you have to drill it out.... hmm..... Surely a smooth, flat bolt/screw thingy would have been better!?!
You ever tried gettin a smooth self tapper? :lol:
Can't say i have! Guess i'll go hide in my hole of no-knowledge pilgrim. :unsure:
A better solution would be if Matt fitted wheels of the correct size, but then he wouldn't be as special as he is! :lol::thumbsup:
Let's hope he doesn't have a bump and have to take it off, eh?
Looks neat though. Always thought that bolt looked tatty. Nice job. :thumbsup:
Seriously kerbed those wheels though matey. :rolleyes:
Only issue with this is that the bolt has a bit that goes through a peice of plastic that holds the bumper on ... and if it gets knocked it likely to either split the plastic or tear the wing and or wing/liner.
But I can see that this might help the rubbing problem.
:huh:
Oh well
Seveer, i dont mind drill as long as its on safe, the bolt came off on one side so i HAD to do something!
Ever since my repair iv been tightening nuts up and stuff its quite worrying, my seat belt jammed on me too! :wacko:
thats exactly what i did
works wonders!
That is a tad worrying... fair play then fella, glad you found a solution to your woes!
F*@( me!!!! 215 tyres!!!! i thought i was big wnough with 205 on 17x7.5. arches rolled and wheels shaved on monday. camber bolts too so should be the end of my probs.
why would you have such piddly ubikd small wheels in the first place with like 3 inches of arch clearence????? theres just no need at all get it on the deck!!!!!!!
yeah and why have piddly normal wheel arches when you could cut them off and replace them with badyld painted foxes buiscut tins.
:lol::lol::lol:
