4a-ge Engine Bits
System~G
After swapping the engines, I have a surplus of bits I probably won't need.
For those who don't know MKIa refers to the blue top engine and MKIb refers to the red top engine.
Firstly there's the Plenum/intake/Throttle body thingy refurbished as seen in this pic (without all the hoses and sensors on it). Can send another pic too...
Will be going on eBay over the weekend unless a decent offer is received. Usable only on MKIb engines.
Then I have the following (pics available on request):
MKIa:
* Injectors and fuel rail
* Clutch, Cover Plate & Flywheel (flywheel bolts available but not the 6 needed for the cover plate - can use your old ones)
* Cams and all fixings
* Cam pullies
* Water pump
* Manifold heatshield (underside)
* Manifold gasket (used, but good)
* 16 X Valve Buckets with shims (First refusal to Vashy)
* Cambelt tensioner & Spring (First refusal to Vashy)
MKIb:
* 1 pair rear springs
* Both front calipers
* Flywheel & Bolts
MKIa & b:
* 2 X distributors with caps and rotors
* Altenator with brackets and bolts
* Cam covers to be refurbished before sale
* Release cable for spare wheel well (front bonnet)
* Release cable for boot (can also be used for engine bay lid)
* Plastic cam belt covers (top two) (First refusal to P_J_Smith)
I think that about it for now. If there's anything from the engine anyone wants, please ask ;)
