Need Clarification Over Wheel Fitment.
MSC_Kev
Hi!
Looking at replacing my wheels and I have found some but the car fitted with them has different fitments to the corolla, but only just. They are 17's from a Rover 600 which has the following measurements.
PCD 4 x 114.3
OFFSET 35
CENTRE BORE 64.0
When the corolla is:
PCD 4 x 100
OFFSET 35-38 (wheels I'm looking at are 40, same as my current 17's)
CENTRE BORE 54.0
Now I'm thinking that the difference isn't enough to cause any problems, can anyone confirm this before I buy?
thanks
Kev :thumbsup:
Hi!
PCD 4 x 114.3
OFFSET 35
CENTRE BORE 64.0
PCD 4 x 100
CENTRE BORE 54.0
thanks
Kev  :thumbsup:
They wont fit. The Spacing between the wheel holes is all wrong.
Have a look at the 200/400/ZR/ZS for wheels with 4x100. C/Bore is 56 on those.
Look at the MGR 17" Straights as they are 7jx17, 4x100, 40mm offset and should bolt straight up.
HTH
EDIT: The 17's you are looking at are from a 800 Vitesse Sport if they are OE WHeels.
