It's a Camry Estate 1994 2.2l. The lock and window mechanisms just packed up. I have looked behind the kick panels and the usual fuse boxes but can't identify the right one. There is no power at the window switch panels. Any ideas?
Found the fuse. Under the instrument panel. Replaced a 30A blown fuse and all but the driver's window is operating. There is volts at the switch and the switch appears to work OK. Is this a duff motor? Got one already at the back near side. Are these still obtainable?
Whip your door panel off and check for voltage at the motor when you operate the switch - might just be a corroded block connector at the motor.
