Help Guys!
94carinaowner
HI GUYS
i recently installed a new sony HU (CDX s-1000) in my 94 carina e Xli. i chopped off the two blocks that connect to the original factory stereo. i then simply connected the two same wires to each other (one from the HU and one from the car wiring). the car did not come with rear Speakers so i have put 2, 6.5 inch alpine woofers (spr-176a) on the rear shelf. they are component Speakers so they come with 2, 1 inch tweeters aswell and also two crossovers. (SEE LINK!) spr-176a
i did not modify the original front Speakers which are mounted in the door. when i installed the system, one of the tweeters burnt out due to extreme heat so i chucked it away. i did not install any additional equipment such as an amp or the crossovers that came with it. so at the moment, my system is made up of : -
SONY HU, 2 ALPINE WOOFERS, 2 FACTORY SPEAKERS AND 1 TWEETER.
yet i have a problem. it concerns the rear speakers only. when i increase volume to about 33% of the full volume, the rear speakers start to give off a terrible sound. this does not occur in the front speakers. i am not sure why this problem occurs. the speakers are not in contact with any objects. i have tried to solve it by disconnecting the tweeter but this does not work!
please can someone help me as i do not know what to do??????
O YES BY THE WAY, WHEN I WAS INSTALLING THE HU, I BLEW THE MEMORY AND REPLACED THE FUSE. THIS DID NOT REPLACE THE MEMORY SO WHEN I TURN OFF THE CAR ALL MEMORY IS GONE. DONT THINK THIS HAS ANYTHING TO DO WITH THE ABOVE PROBLEM BUT COULD SOMONE HELP ME WITH THIS ASWELL????
THNKSA LOTGUYS 4 ANY REPLY!!!!!!!!!!!
HI GUYS
i recently installed a new sony HU (CDX s-1000) in my 94 carina e Xli. i chopped off the two blocks that connect to the original factory stereo. i then simply connected the two same wires to each other (one from the HU and one from the car wiring). the car did not come with rear speakers so i have put 2, 6.5 inch alpine woofers (spr-176a) on the rear shelf. they are component speakers so they come with 2, 1 inch tweeters aswell and also two crossovers. (SEE LINK!) spr-176a
i did not modify the original front speakers which are mounted in the door. when i installed the system, one of the tweeters burnt out due to extreme heat so i chucked it away. i did not install any additional equipment such as an amp or the crossovers that came with it. so at the moment, my system is made up of : -
