Advice On Hks Cams
Bootygrabber
Right, been looking at these..but i was wondering if any1 had actually fitted them in their celica....I driving a Gen 6 GT and was just wondering what sort of BHP increase they would give me? I am looking at the mid lift cams..
Any info would be great
Cheers
Martin
There's no point in installing more aggressive cams in the ST202. It already makes peak power at 7000 rpm, which is redline is it not? The ECU will cut ignition/fuel just beyond that so you're not going to gain anything. But you will have a lumpy idle and loose low rev driveability.
If you have the underlying mods for aftermarket cams (built bottom end and aftermarket ECU), then you are getting into race engine territory IMO.
