Friends,
Where can I find Poliurethane suspension bushings for tm Starlet Glanza,is possible that from other Toyota models can fit?
Tks
Hi mate,
Welcome to TOC
I'm sure that some of the Starlet owners will know of the best place(s) to try out. There'll be someone along soon - there usually is anyway.
Rich
your link has been administrated :unsure:
Hence the edit !
lol, yeah, NOW you eddited it :P
  • 2 months later...
Friends,
Tks
Can supply Swaybar D bushes and bushes for the links off the shelf.
Also inner and outer lower arm bushes.
Whiteline do a Castor kit which has an offset outer bush for the lower arm. This allows for more castor adjustment.
Other than that you need to look to either Cusco or TRD for hardened rubber compound bushes on parts such as the rear end.
Cheers,
P. ;)
What exactly is a bush? and what does it do?
Just out of curiosity
