I have been told that the front and rear tyres are different and I need to know the stud measurement and offset? any advice?
hi
my sister has had some 17" wheels put on hers
the offset is 40 on hers and the measurement is 114.3 x 5
the offset to go for is 35-45 and the measurement is 114.3 x 5
the tyre sizes depends on what size wheels you have so let me no and i might b able 2 help ya out.
cheers
acstreet
I have decided on 17's.
Thanks for the quick reply.
17" good choice look gr8 on my sisters
the tyre size are better 2 have bigger rear and smaller front
the sizes are 215/40/17 front and 235/40/17 rear.
but you may need to get spacers to miss the suspension as my sister did but they dont cost 2 much. as she was told by a mechanic otherwise they might rub on the suspension depending on the offset.
the actuall offset with normal wheels on is 38 as i have a mark 2 1990 mr2 with 14" but have 17" to be put on.
any more info just ask me.
thanks
acstreet
Thanks for the info.
thats ok m8 i hope it helped ya :thumbsup:
if you get the correct offset you wont need spacers, the rear needs a higher offset as the body is wider and theyll seem lost, front is 38 and rear is 42,
go for 215/40/17 front and 235/35/17 rear, this will keep the rolling radius as close to standard
