This is what our flexi looks like the manafold on this one looks better then ours :crybaby:
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
  • Roytoner
    17
  • houston
    12
  • BlueMR2
    8
  • DrMR2
    5
this is where it is on n/a, if you removed it do you not have engine light on dash all time?
Posted (edited)
SORRY FOR THE SIZE OF THE PIC'S :!Removed!:
All the dash lights we have.
Took them off they was way to BIG!! :!Removed!:
Edited by Christine & Paul
i got told that i had to keep the sensor on, would have just cut it off i knew i could!
We never had one to start with, going to cut the pic's down before I get SHOUTED at :D
Hi Chaps,
I have just bought myself a great little 2.0 16v GTi, and i love it, so i am new to this forum, but it looks great!
Just reading the posts on the sensor changing, how much does it cost for a garage to change it?
Hi Chaps,
If it's a U.K. model it may not have one :yes:
Hi Chaps,
Yes it is a UK model, sounds good! Thanks for the quick reply too!
Any ideas to help with the horses, but nothing too expensive or technical! N/A engine.
Hi Chaps,
Which ones??
On the tubby there is a sensor at the top of the downpipe/cat pipe near the dipstick as someone said. I'm sure there is also a sensor at the bottom of that section of pipe too. My downpipe has two sensor holes at the bottom, easy to monitor on the rollers.
Joe
Hi Chaps,
Which ones??
I bought the car two weeks ago and am thrilled with it, just wondering if there are some inexpensive tips or tricks i could use to get that little bit more power out of it. Also my fuel consumption is about 150 miles from £20, is that about normal??
To tell you the truth there is not alot you can do on the cheap,
You could get something like a Mongoose exhaust, and a induction kit,
then you start having to spend on things like a better e.c.u. + things.
Appreciated advice, thanks.
You are welcome :thumbsup:
hmmm mite have to try the 'tap' trick
if its naffed will it fit the turbo, the Halfords gubbin that is
ive heard an OE toyo one sets you back about 150pounds! :eek:
if its naffed will it fit the turbo, the halfords gubbin that is
Seen a site somewhere where they are alot cheaper then that :yes:
Will try and find it for you. It's been along time since I was looking at it.
Have a look HERE!!
Hi Guys,
Is 150 miles on £20 about right? Any methods apart from sensor cleaning/changing to improve this if its drinking too heavily?
i take it they are universal gubbins anyway
not manf. specific?
Just had the top sensor out on mine, looks fairly clean tbh. Maybe the guys who fitted my downpipe cleaned it up. I'll check the bottom one next time she's up on the stands. The top one is held on by 2 nuts, you have to move the turbo heat shield to get to one of the nuts.
Joe
Hi Chaps,
The UK models definately have them have them, I've just looked.
Hi Chaps,
Rev one's don't
Hi Chaps,
Rev one's don't
:unsure:
There is no wiring for one, no hole in the exhaust for one, no warning light on the dash ...
So a Rev3 would not have one??
:wacko:
