T-sport Supercharged
yarislad2004
I just bought a mini cooper s supercharger that only has delivery mileage on it.
Now i have been told that the engine will cope with power of the charger.
Does anyone know any different??
good luck fitting it matey :D i work in engineering and i have one off a cooperS, i know what it needs i know how to fit it. did you get the by-pass valve?
i paid £75 for it. i don't know if i have got the by-pass valve with it.
you couldn't by any chance tell me what i would need?
new inlet manifold, a pully which runs the belt around the engine mount, mounted on the alternator bracket,new alternator bracket (to move the alternator out of the way), bypass valve, new crank pully, alternator and power steering pump pullys (because a 3V belt isnt relieable enough to cope with the strain) also moving about of wires pipes ETC. and if you want it to run properly you'll also require a custom ECU.
all custom made aswell.
sorry little off subject but yarislad2004 were u at bolton cruise on thursday night
no don't really go any more.
earpl,
i take it all these parts will be uprated?
no all these parts will have to be made in order to fit the charger. i'll happily let my bypass valve go for £100
still want to do it :D
just found out that it comes with the by-pass valve
cheers anyway mate
on the red ducting?
hope youv'e got enough cash to do it, i estimated about 2 grand, with making some of the bits myself.
Before you decide to go ahead with the charger get hold of "Supercharged!" by Corky Bell. It's a comprehensive book with lot of info - well worth a read.
