Servicing Help !
After recently buyiny my MR 2 i decided it would be a good idea to do a small service on her.
I have the usual stuff:-
Oil
Oil Filter
Air Filter
Spark Plugs
What tools will i need (including sizes) in paritcular i am refering to the sump plug.
IS it fairly easy to get to and work on ? I used to own a 106 rallye which was a really easy to work on for servicing.
The small orange oil light keeps coming on intermitantly its the onw with the "flames" underneath it, so i assuming its telling me the oil is too hot.
Thanks for any help, sorry if its in the wrong section but i wanted a few replies as i need to change these things before my long drive to London tomorrow
Scott :)
I think spark plugs are 17mm (but might require deep reach socket / SP Tool)
Oil Filter might require a remover chain to get it off
Sump plug.......huummm, i cant remember, but they are norm a socket / alan key
Normal socket (12 or 14mm I think) for sump plug.
Oil filter - a pair of rubber gloves :)
Or just stab a screwdriver through it, and twist it of.......not pretty, but it works ! :yes::thumbsup:
Be carfeul when changing the filter, it's located just under the heat shield which will be v hot after running the engine to heat the oil up...
It's very easy to burn yourself on it when taking the filter off....
Depends on the revision, rev3+ it's and the bottom of the engine.
Good advice for the rev1-2 though :)
