Help
wendy
Has anyone any suggestions as what could be the problem with my car. Whilst driving i lost power and the car came to a standstill. The car will turn over and run for 3 or 4 seconds but then it dies.
Hi - as the engine still runs (albeit very briefly!) hopefully you can rule out timing belt failure or massive overheat.
At a guess (and I'm no mechanic!!!) this could be an ECU failure (engine management computer chips). One for the garage (or one of the good mechanical people on the forum - they're very good and helpful).
Fuel starvation...get your fuel filter and fuel pump checked.
an after thought...was it misfiring at all? Could be an Air mass meter issue , possibly loose connector or at worst a failure on the meter. Located under the bonnet by the Battery. Check the connection first.
an after thought...was it misfiring at all?  Could be an Air mass meter issue , possibly loose connector or at worst a failure on the meter. Located under the bonnet by the battery. Check the connection first.
Hi no it is not misfiring at all, thanks for the suggestions, will get them checked out asap.
