2005 Corrola Radio (w58814) Remove Help
m14rts
Hi .
I am trying to fit a nokia car kit to my T3 2005 corrola. with radio W58814
I have already brought the adaptor kit so the phone will play through the Speakers ..
How do you get the radio out ..
Does anybody know if the radio has a tel mute function and which pin is it .
Also can you get Sat nav to work on this radio with the right kit .
and one more ...
on the mpg readout can you hack into that to give other info ..
Thanks in advance ..
Great site..
Martin
I can help you with the removal part of you request :thumbsup: , but the rest your on your own, don't have car kit in my car :huh: , don't have sat-navi :huh: and couldn't tell you if you can access other info from the MPG function :huh:
will give it a go ....
Providing Toyota haven't changed the dash too much with the model updates, should be the same :thumbsup:
Nep!
Toyota has completely changed the dash and the head unit and it looks very different than your pictures. If you could check the interior pics of the new corolla and verso form toyota uk web page you would notice the difference.
I am still searching for a guide to remove my own head unit to install a sat-nav unit and/or a colour lcd.
The pics you see, are for the Corolla, not the Verso dash.
The pics may look different, but that because i've changed it to my own H/U instead of the Corola own, but what you see is the same in all the Corolla's dash.
It might be different to take tem apart, but if thats the case, i can't help you there.
Hope that helps.
:thumbsup:
Hi .
I have already brought the adaptor kit so the phone will play through the speakers ..
and one more ...
Great site..
Martin
I'm about to fit my Nokia Handsfree kit into mine.
Can I ask you which bracket you got, where it sits, how much it was ?
Oooh and the adapter to have it running through the Speakers?
Questions Questions :D
Cheers
Steve
Check my homepage
you must begin by the gearknob than the pull the plate with the leadersocket from the gearknob up
Than pull the front of the heather consul straight forwards from under to the radio than you have to unscrew to bolts and pull the radio forwards to you
check my homepage :thumbsup:
I've got a link on my signature that shows how to remove the dash as well :thumbsup:
Yes you can have sat nav running through the OE radio. However it will have to be the Toyota unit which ain't cheap! Best consult your Dealer for prices.
As for the phone kit, there is a mute function built into the radio. You will have to connect the mute wire from the phone kit to one of the connectors of the radio. Can't remember which wire off hand, should say in your instructions!? If not I can find out.
