Brake Calipers
jezzagold
I have just gone to change the brake pads on my 2000 Avensis GL and found that those tricky guys at Toyota have replaced the two retaining bolts on the brake calipers with bolts which do not have the standard hexagonal bolt head. They seem to require some sort of allen key to undo them. Does anyone know if this is a standard allen key fitting (an if so what size ?) or is it a special Toyota key required ?
Thanks!
its either a torx key you need or an allan key , dont know what size ? sets can be bought for less than a tenner.
