My EFI Surf has a fuel leak from the top plate on the injector fuel pump. There is a plate held on by 4 allen key bolts that has the return from the injecters and the return to the tank bolted to it there is also a sensor on it ???? the joint between this plate and the one below is where the fuel leak is from. is there a gasget between these bits and is the plate removable or are there bits that below this plate that might move?
Cheers Jon
You will need to disconnect the sensor then remove the pump cover, once you have that out of the way you can fit a new seal.
Injection Pump Seal Kit 003728/3 £7.80 from http://www.milneroffroad.com/LN130.htm
